RPM's bouncing in idle after Seafoam
Old Aug 23, 2013 | 10:36 AM
David1221's Avatar
Hey guys, I just did the seafoam through the main vacumn line and now my rpms are bouncing a little at idle. What do you think the cause is?
Old Aug 23, 2013 | 10:37 AM
did you hook the vacuum line back up?
seafoam will cause it to idle funny until all the seafoam is gone
if you made sure vacuum line is hooked back up, give it some gass!!!!!!
Old Aug 23, 2013 | 12:28 PM
03 tls nc's Avatar
Not really much to go wrong, I have noticed on some vehicle that after using seafoam they ran a little different for a couple hundred miles. I think it is affected by how gummed up every thing is in side. I would dive the sh*t out of it for a couple tanks and see how it does.
Old Aug 23, 2013 | 01:11 PM
David1221's Avatar
Yeah you guys are probably right. A couple of times I have started it and it has been all right so I guess it's just working itself out. It does have 242,000 miles also so it's probably a little dirty...
Old Aug 26, 2013 | 02:33 PM
David1221's Avatar
I fixed it...while cleaning my throttle body I noticed a little line that was disconnected. Of course I hooked it back up and the car immediately went to a smooth idle. I'm at 242,000 and I'm gunning to see if I can get to 500K at least. It's been a great car and relatively easy to work on as well.
Old Aug 26, 2013 | 07:10 PM
3.2TLc's Avatar
Good luck, take each 100k milestone one at a time and keep up with the good "PM".
Old Aug 26, 2013 | 07:45 PM
03 tls nc's Avatar
David glad you got it fixed!!
That little stuff will drive you crazy some times.
acuratl26
Apr 23, 2020 07:30 PM
DerrickW
Nov 15, 2015 05:52 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
mdlex389
4G TL Problems & Fixes
Sep 28, 2015 06:29 PM
prbori
Sep 27, 2015 01:37 AM
