RPM jumps and then rough
Old Apr 15, 2010 | 11:36 PM
F35's Avatar
F35
Hi to all! I'm new to this forum and have a JDM Honda Inspire 2002 TypeS SSM. Live in Russia. I have a problem and can fix it about 2 years cause nothing helps me. When I accelarating and then release a gas pedal, my RPM fast go back on 750, then jumps to 1200-1500 and then slowly goes back. But sometimes its rough on the 500 rpm at stoplights. I have no touble codes, scan diagnostic does not find something strange. I put new IACV, clean throttle body, intake manifold, injectors, change spark plugs... I cant find some vacuum leaks and I didnt know what i shall to do else. Have you ane suggestions to resolve this problem? Thanks!
Old Apr 15, 2010 | 11:39 PM
F35's Avatar
F35
Also i inspect a MAP and an oxygen sensor - its normal.
Old Apr 27, 2010 | 10:41 PM
friesm2000's Avatar
B A N N E D
when you replaced the idle valve did you also replace gaskets too???
baelim
May 10, 2018 09:53 AM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
DerrickW
Nov 15, 2015 05:52 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
ceb
ILX
Sep 27, 2015 10:56 AM
