Right HID keeps flashing
Old Dec 2, 2007 | 10:14 AM
AMGala's Avatar
Lamborghini Aventador FTW
I tried searching but I couldn't find much information. Basically, periodically my right HID flashes, like there is a loose connection or something and it keeps going in and out. I read something about regrounding the headlights, but I don't know where they are grounded? I've taken my housings out before, I having seen any grounding wires attached to them. Is it my ignitor or ballast going? Or is it just a loose connection? Any help is appreciated.
Old Dec 2, 2007 | 10:29 AM
01tl4tl's Avatar
I would swap the bulbs left to right and see if it does the same thing
If It goes away- you have bulb failure in your near future
If it doesnt fix it- likely ballast- see auto recyler yard for used unit
If the ignitor goes- it wont ignite
Can you park in front of a wall so when you turn on the lights you can see them?
If pink for a split second or 2 seconds- thats the other bulb failure indicator
Always replace in pairs
Old Dec 4, 2007 | 08:42 AM
AMGala's Avatar
I'll try swapping bulbs, and I really hope it's not bulb failure, they are less than 6 months old! They are definitely not pink, still bright blue.
Old Dec 4, 2007 | 10:48 AM
01tl4tl's Avatar
bulbs or ballast is still my best guess
What brand bulbs did you use?
Old Dec 9, 2007 | 03:50 AM
Tech7427's Avatar
Under your Acura...
replace the ballast and ignitor..
around 700
Old Dec 9, 2007 | 10:23 AM
01tl4tl's Avatar
shop the auto wrecker-recyclers and save big on those items!
Old Dec 9, 2007 | 10:41 AM
Tech7427's Avatar
Under your Acura...
or just buy an aftermarket system and still save big and get away from the far from superior factory based ballast/ignitor system
Old Dec 15, 2007 | 01:15 AM
AMGala's Avatar
I have 6000K Kaixens, same as you!
Old Dec 15, 2007 | 11:03 AM
01tl4tl's Avatar
If the problem is still happening- ballast from auto recycler or check the private sales in Black Market here on azine
Old Dec 16, 2007 | 12:28 AM
jjashaa's Avatar
Avant Garde Wheels
i had my left light flash on me.. took it to Acura dealer, they said something about an Invertor i'm guessing they were talkin about the ballast.. i uno.. and i asked about the price and they said 700.. i said.. i'll think about it and i'll call back.. took it to a nice little shop near my place and the guy checked my fuses and just replaced my fuse that was broken i guess. next thing i kno, my lights are back on. best part about it, it was FREEEE.
Old Dec 17, 2007 | 08:26 PM
AMGala's Avatar
Do you remember which fuse it was?
Old Dec 18, 2007 | 02:05 AM
01tl4tl's Avatar
there are main headlight fuses and relays- look in the boxes under the hood- everything is marked
If you find one blown- find the short in the system before replacing and blowing another!!
Old Dec 18, 2007 | 03:44 PM
jjashaa's Avatar
Avant Garde Wheels
nope.. sorry. hahaha,
Old Dec 19, 2007 | 03:10 PM
AMGala's Avatar
Well I finally got a chance to look at the bulb... My best guess is that the igniter wasn't seated properly around the bulb. This might have caused an electrical arc which melted the bulb base and the igniter. It is very odd though that they had been working fine for a few months and then only now did this problem happen. Here's a couple pics of the bulb. Anyone have any insight?
Old Dec 19, 2007 | 03:29 PM
01tl4tl's Avatar
condensation caused arcing? hows your housings? and the cover seal for the back of the headlights? anywhere wires go thru allowing moisture in?
Old Dec 19, 2007 | 03:37 PM
AMGala's Avatar
Housings are OEM, never cleared. I did have a little bit of an issue with fogging but it went away with a couple of days in the sun. The cover seal is nice and tight. I have a set of cleared headlights made by JnC that I will be eventually putting in once I get a new igniter, so I'll make sure everything is closed up.
Old Dec 19, 2007 | 03:39 PM
01tl4tl's Avatar
fogging inside the housing counts as moisture!
The seal on my OE housings had that prob- never opened at all and still they wore out
Old Dec 19, 2007 | 10:30 PM
AMGala's Avatar
So do you think it was just the igniter? Or could it also be the ballast?
MilanoRedDashR
Oct 8, 2015 10:30 AM
thegipper
Sep 28, 2015 01:01 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
