Right Head Light problem!
.a BUM with SMG...
Does ani one knows anything about the right head light , cuz mi head light just wont turn on and the left one works fine. I took it out and see whats wrong and those bulbs are working fine , so ani ideas guys ? thanks
You tried the swap left to right with the bulbs, and the one side has no power- is that correct?
Then you probably need a ballast and maybe an ignitor
If one bulb works on both sides- you need a new bulb
Buy in pairs or the light output will be way different
ebay 85$ pair Phillips 4300K dealer 165 per bulb!
or kaixen 5000 or 6000K from vendor excelerate- i have the 6's and they are a nice cool white with blue- picks up road marking and signs really well
.a BUM with SMG...
yeah oh when i plug the bulb from my driver side to the other side, jus wont turn on , so it fucked up some wher in the ballast or an ignotor as you said ?
or maybe my friend hooked up a amp and sub system for me yesterday , it might cause ths problem right ?
Maybe the thing ur friend hooked up is just a kawinki dink, but your ballast may be gone. Switch the ignitors and see if that helps. If not, your ballast is gone. There's lots for sale right now on the BM.
batteries ballast and low beams- welcome to winter prep!
cycdaniel
12-17-2019 10:58 AM
RLX-Sport Hybrid
3G RLX (2013+)
43
12-16-2015 10:45 PM
