reset cel
Unregistered Member
If you're a ssuuuuupppper noob like I was, just disconnect your negative(-) battery terminal for about 10 minutes. If you do this, MAKE SURE you have the radio/navi codes.
The better way to do it is to pull the clock backup fuse. It's on the passenger side fuse box. When you pull the cover, there's a sticker with the labeling for it. The fuse should have 7.5 written on it. Just yank it out, and put it back in a minute.
