99 TL periodic starting issues
Old Feb 5, 2011 | 04:20 PM
jirand's Avatar
My 99 TL has a bad habit of not starting after it's been running for awhile:
1. Drive car until the it has reached full operating temperature
2. Park it for a while, the car starts fine
3. drive a short distance, park the car for a short time
4. Car will not start. The starter is turning the engine, all accessories work but no start
5. wait 3 to 4 minutes, car will start no problem
This behavior is very consistent. I took it to a mechanic (not an Acura specialist) and he couldn't find anything wrong. Has anyone else had this problem & were you able to find a solution?
Thanks!
Old Feb 5, 2011 | 05:17 PM
01tl4tl's Avatar
99s have a problem with the ignition switch back- electrical part
While those are not the common symptoms, I would start there
usually it turns off and back on when driving- especially on turns
call acura care and see if it was ever replaced under the recall 1 800 382 2238x5
or your dealer can run the cars VIN and ck for you
They only cover it once- then its on you the next 2-3 times...no kidding
use same part and expect better results? go aftermarket less than 50 bucks
see DIY section for help on install
stop by a parts store and ask for electrical system test- its free and test batt alt and starter, wires etc
short drives dont allow the battery to be fully recharged after the starter draws from it
How are the spark plugs, air filter? no smell of fuel leak under hood?
Old Feb 7, 2011 | 03:04 PM
TLer trash's Avatar
Your symptoms would also be consistent with a main/efi relay.
Old Feb 7, 2011 | 05:59 PM
01tl4tl's Avatar
nice call trash!!
someone had the FI relay bad recently = fuel injection relay- look under hood for relay blocks
you can swap them within same color (borrow one from another circuit) to test
Old Feb 8, 2011 | 08:50 AM
TLer trash's Avatar
Originally Posted by 01tl4tl
nice call trash!!
If only it were that easy. This one is a double relay in a metal case that bolts in approximately above your left foot under the dash. They're commonly intermittent, hence hard to test.
Old Feb 8, 2011 | 09:09 AM
01tl4tl's Avatar
the things I dont know!!
Old Feb 15, 2011 | 08:51 PM
gator_bait's Avatar
5th Gear
This is a very common issue with aged Honda Automobile's. Had to change one on my CRX years ago and recently on my TL (past summer,OE part for about $60 and one small band aid). One of the most common symptoms of the "Main" relay failing is during a hot day your car wont start. Temporary remedy..open the windows and wait a few minutes. Then attempt to start.
It is a PITA to get to especially without bloodying up your hands.
mada51589
Jan 9, 2025 04:40 PM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
SilverJ
1/2G MDX (2001-2013)
Sep 21, 2015 02:40 PM
PortlandRL
Sep 14, 2015 12:01 PM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
