Radio needs code like every 3 weeks
Old Feb 8, 2010 | 01:34 PM
99AcuraTLAndy's Avatar
My 99 TL needs the radio code like every 3 weeks entered to work. This started to happen about 3 months ago. Enter the code set the stations fine then about 3 weeks later get in car start it up radio is asking for code. Has this happened to anyone? Clock is fine and Temp control is fine as well just the radio asking for code. After code is enter it is fine just have to reset stations and then wait a 3 weeks for it to happen again - weird???
Could this mean radio is broke or dying???
Thanks.....
Old Feb 8, 2010 | 02:01 PM
fsttyms1's Avatar
My guess is its probably something wrong with the radio. Its possible that the battery voltage drops enough to cause the radio to loose power enough to think it needs it. How old is your battery?
Old Feb 8, 2010 | 02:11 PM
About 3 years now. Car turns over fine. Starts right up even in this cold weather.
Old Feb 8, 2010 | 02:44 PM
NSXNEXT's Avatar
Make sure the battery terminals are on the battery tight (but not too tight). Check to see if there are any loose ground wires too.
Old Feb 8, 2010 | 02:54 PM
totaledTL's Avatar
Load test the battery. Inspect the wiring to the radio- maybe a memory lead has a poor connection.
Old Feb 8, 2010 | 03:54 PM
I will get a load test done on battery (etc. there) but if it was the battery or a loss wire wouldn't the clock (would be incorrect), temp control, and head seats switch all use the same wiring (housing) to get power?
Old Feb 8, 2010 | 04:22 PM
fsttyms1's Avatar
Radio has a separate fuse and wiring. The voltage may be dropping just enough to trip the need for the code.
Old Feb 8, 2010 | 04:32 PM
Okay THANKS! Didn't know that thought it was the same wiring (housing unit) for all 4.
So the radio wire goes right to the fuse box with its own fuse?
Old Feb 9, 2010 | 06:45 AM
totaledTL's Avatar
Most radios have a separate always-on 12v lead to retain the memory settings, often a yellow wire.
mada51589
Jan 9, 2025 04:40 PM
Yikes
May 3, 2021 04:29 PM
handsom-hustla
Nov 13, 2015 05:04 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
NSolace
Sep 3, 2015 08:14 PM
