Problem w/IMRC valve after EGR cleaning
03 TL-S
Decided to take-apart and clean the IM.
Everything was fine until I tried to reinstall the IRMC valve.
As the following picture illustrates, there is clearence between the stopper and the screw when there should be none.
The only way to fully close it is manually, as pictured below.
How do I fix this?
PS. The cars idles a tad bit higher than normal, otherwise it runs fine.
How do I fix this?
03 TL-S
Did you take the IMRC OFF the im when you cleaned it? If so is it installed correctly?, remove the upper IM cover and make sure the rubber seal isnt blocking it, or hanging in the way
