Problem with trunk not opening..
Old Jan 25, 2006 | 12:34 AM
PiMpiN wHITe Cl-S's Avatar
well this just happened today. my trunk does not open at all unless i use the emergency latch in the trunk. If i use my remote or button on the driver door it does not open. could this be a fuse? any help will be appreciated.
Old Jan 25, 2006 | 03:29 AM
chewi's Avatar
maybe your trunk is locked by the switch in the glove compartment
Old Jan 25, 2006 | 11:19 AM
^ nope. checked that already.
Old Jan 25, 2006 | 11:27 AM
honda_inspire99's Avatar
Skeet Skeet Skeet
having the same problem need help too
Old Jan 25, 2006 | 11:30 AM
so your trunk doesnt open with the key FOB and even by pushing the button inside the car? cant figure out what the problem is and now i have to open the trunk through the rear seats everytime.
Old Jan 25, 2006 | 12:09 PM
fsttyms1's Avatar
Fuse or selonoid on the trunk that releases it
Old Jan 25, 2006 | 12:12 PM
^ do you happen to know of which fuse it is? its on the passenger side correct?
Old Jan 26, 2006 | 09:47 PM
ncxvtguy83's Avatar
Try checking No. 12 on the passenger side fuse box. It should be a 20A. Let me know if it works.
Old Jan 26, 2006 | 09:56 PM
Mar T's Avatar
Marty_1999Acura3.2TL
It's also in your manual.
I’m almost positive that it’s your fuse. If its not, be prepared to spend big bucks. Good luck.
Old Jan 26, 2006 | 10:00 PM
thanks guys! i will check that and see if i need a new fuse. yea i use the trunk everyday so everytime i have to go though the back seat..what a bitch. but thanks!
Old Jan 27, 2006 | 04:48 PM
heygfy's Avatar
Let me know if that worked
I am having the same issue. I will also check my fuse tonight.
Old Jan 31, 2006 | 05:52 PM
hey i checked the fuse and it seems to be fine. which part would i need from the diagram below if i were to replace the solenoid.
http://www.acuraautomotiveparts.org/...prddisplay.jsp
Old Jan 31, 2006 | 05:59 PM
fsttyms1's Avatar
Appears to be #24.
Have you opened the trunk with the saftey release cable to look at the lock to see if the wires still conected? or tried testing that its getting power?
Old Jan 31, 2006 | 06:03 PM
^ i have tried using the emergency latch, and that works fine. also when i check try opening the latch by remote/button i hear a tiny sound (like a click) coming from the fuse box area on the passenger side. ill go check it again right now to see if there are any disconnected lines.
Old Jan 31, 2006 | 06:29 PM
well everything seems to be intact. fuse is ok, line connected, so now i guess its the solenoid in the latch that seems to be the problem..?
Old Jan 31, 2006 | 06:56 PM
fsttyms1's Avatar
Yes it sounds like thats the problem then.
Old Feb 2, 2006 | 06:03 PM
can anyone see if it is the #12 fuse on the passenger side? when i looked at it say it was for power door locks..? well i just want to make sure its not something else before i spend like 60 bucks on the whole lock. thanks!
Old Feb 2, 2006 | 08:09 PM
nm..i am 90% sure its the lock. ordering the part tomorrow, let you guys know how it goes.
Old Mar 16, 2008 | 06:08 PM
axleback's Avatar
Did replacing the lock assembly fix your problem?
axleback
mada51589
Jan 9, 2025 04:40 PM
spoiler900
May 25, 2016 10:16 PM
BoricuaTL
Apr 8, 2016 01:08 PM
VA2000TL
Oct 2, 2015 08:26 AM
brandnewcolony
Sep 12, 2015 10:39 AM
