Problem playing burnt CD's?
Old Dec 26, 2006 | 06:29 PM
MadHatter's Avatar
Smoke something...
Hey guys. I have a 2003 TL (non Type-S) with the stock 6 disc CD changer. When I try to play a burnt CD... the last few tracks play terribly. The songs skip really really bad kinda like the CD itself is scratched. But the weird part is, its only the last few songs on the CD. Has anybody had this problem before?
- Mad Hatter -
Old Dec 26, 2006 | 06:51 PM
Richard in Atlanta's Avatar
3rd Gear
This happened to me. It turns out that the CD-R's that I bought were defective. I bought a different kind of CD-R and everything works fine.
Old Dec 26, 2006 | 07:28 PM
BuddyC's Avatar
is it just the 2003 TL-S that can play burnt cd's? I've tried playing them in my 02 and no luck? or is just the discs that I use which is memorex?
Old Dec 26, 2006 | 07:36 PM
MadHatter's Avatar
Smoke something...
okay... i burnt a bunch of Sony CD-R's... and they are one of the many that play horribly. then, i tried Maxell CD-R Music... i guess they're specifically meant for music files... and they worked fine. then i bought a 2nd batch of the exact same CD's from the exact same store... and they too play bad. this is getting really confusing.
Old Dec 26, 2006 | 07:37 PM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
My 02 TL plays burned CDs just fine. As did the 99TL I test drove. As does the stock CD player in our 98 Camry. I've always wondered why people have problems with this when I never have.
Old Dec 26, 2006 | 08:24 PM
BuddyC's Avatar
what discs are people using? i've used memorex and they don't play? you're using regular format correct, no mp3? what speed you burning at?
Old Dec 26, 2006 | 08:41 PM
Malayalee King's Avatar
ഥഎണഡഏ Fellas Inc.
i have used memorex since the knock off ones werent always too great.
i find that slowing down the burn speeds on generic media will remedy more often than not.
word to the wise, if you plan on labeling them don't use the stick on cd labels. depending on the existing cd coating (top, not burn side) if you stick a label on you may get the cd stuck in the player! *happened the first month i got the car*
good luck
Old Dec 26, 2006 | 08:48 PM
TLsMD's Avatar
WINNING
I have a 03 tls and play burned cd's all the time, I use sony, memorex, and some other knock of brands...so far have had no problems with any of them..
Old Dec 27, 2006 | 03:44 AM
Leo Type-S's Avatar
03' NBP TL-S
you probably just had buffering problems when burning the cd.
Old Dec 27, 2006 | 04:32 AM
Rpappi's Avatar
DRINKING HAS A ME PROBLEM
different batches will play. so you can buy a memorex on time and go get the same one next and it wont work the second time. its really hit or miss.
Old Dec 27, 2006 | 06:11 AM
SwampGas's Avatar
/etc/car
I have a 2001 and cd-rs haven't worked for a few years now. It started by taking forever to read the cd-r or if I skipped the first few tracks, but then it just stopped.
I took it as a sign to get an ipod, so I did
EDIT:
forgot to mention that if it's the end of the cd, it could be a calibration error on your burner (the cd spins faster on the outside of the disc) or you're over burning, which doesn't always work.
Old Dec 27, 2006 | 06:33 AM
BuddyC's Avatar
hmm interesting. i will have to give this another try by slowing down the burn process once my car comes back from the body shop. thanks
Old Dec 27, 2006 | 08:30 AM
SwampGas's Avatar
/etc/car
That helped a little bit, but everything eventually stopped working. Burned at 8x instead of 52x. I guess there's less deviation when the disc is spinning slower.
Old Dec 27, 2006 | 01:06 PM
Insomnia1009's Avatar
never had any touble playin burnt cd's (thats all that i listen to) buy imation cd-r's and don't skimp on a nice rw drive to burn them. lates.
Old Dec 29, 2006 | 10:23 AM
BuddyC's Avatar
Ok so i just realized that I don't have a problem playing burnt cd's. what i was thinking is that the cd player doesn't play burnt mp3 cd's. should the system play burnt cd's in an mp3 format?
Old Dec 29, 2006 | 10:25 AM
ഥഎണഡഏ Fellas Inc.
^ nope it will not play mp3 cds
Old Dec 29, 2006 | 10:49 AM
TLP_TLS's Avatar
i have an 03 TL-S and only play burned cds and they all work fine. weird thing happens once in a while though i get a ErE1 code? anyone know wat that means?
Old Dec 29, 2006 | 11:23 AM
ഥഎണഡഏ Fellas Inc.
^ i think the error codes are in the manual if you still have it. i don't have mine with me; hopefully someone will chime in
mada51589
Jan 9, 2025 04:40 PM
navtool.com
ZDX
Oct 31, 2015 08:26 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
pistacio
Sep 26, 2015 09:45 AM
