Problem with parking lights & dash lights
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
I have a problem with my parking lights, when I turn them on, they don’t turn on at all, and neither do my dash lights, or my climate controle lights all of them are off.
When I turn the headlights on, the headlights turn on, but the parking lights stay off, and still my dash still does not light up; what’s more confusing is that when I turn on my blinker the side that blinks works, the other stays off.
Please help ASAP because I cannot see my speed or any of my gauges at night.
Oh and when I lock or unlock the car, none of the lights flash.
sorry, I read it too fast...I missed the under the hood part, and that was the problem. Acura is amazing becuase there were some spare fuses, so I didn't have to run to the store to get some fuses.
That was an easy fix, thank ya'll
Not sure about a '99 but there are several fuse locations on '02 model. Get familiar with them in advance of trouble. Check the easy things first. Glad you got it working.
after i replaced my fuse the first time i've had to replace it 2 more times because the fuse keeps blowing...but i figured out what causes it to blow, everytime i put the parking brake on; the fuse blows out.
so now i stopped using my parking brake, but last night when i was parking my leg stepped on the parking brakem and there was a flash inside the car by the peddle, as if someone took a pic with a strong flash...luckily i didn't get shocked. but i'm wondering is this a big problem that i need to worry about?
Making offspring in
small lights fuse is 7.5 fuse if im not mistaken. Im having the saME problem iwth mine, the shop is saying a wiring harness needs to be replaced because of something causing the fuse to blow. i think it was a ground problem with me.
dash and parking lights fixed
Thanks to this forum I found the fuse - even though my meter said it was good, I pulled it and visually inspected it. BLOWN!
all fixed now!
thanks AcuraZine!
all fixed now!
thanks AcuraZine!
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
rockyboy
01-25-2016 06:00 PM
