Power Steering Pump - Base vs Type S
Old Jul 6, 2012 | 05:16 PM
PrEmIuM's Avatar
Okay so i have to replace the power steering rack and pinion on my base 2000 TL. We are also going to replace the pump. Can i put a type s Power streering pump in there and everything will be good or do any sensors or anything have to be changed aswell.
Just making sure because i read somewhere that the TL base model is speed sensing and the TL-S is torque sensing. Not looking forward to doing this job, any help is appreciated
Old Jul 7, 2012 | 01:50 PM
Skirmich's Avatar
There are Different Sensors between Type-S and TL-P (Rack and Pressure Lines).
TL-P is Speed Sensitive where TL-S is Torque Based, Both Systems are Different...
Old Jul 7, 2012 | 02:12 PM
The thread below will give you an idea of what to expect for this repair, although it was done on a CLS.
https://acurazine.com/forums/2g-cl-problems-fixes-70/advice-steering-rack-replacement-856844/
Good Luck!
Old Jul 7, 2012 | 02:15 PM
Karanx7's Avatar
Unregistered Member
PS pump is the same.
Rack and pinion different story.
Old Jul 8, 2012 | 08:28 PM
PrEmIuM's Avatar
Thanks for that, do you know if its just a straight swap out for the two sensors? or is there more to it than just that.
Yeah i already picked up the type s rack and pinion, looking for a new pump now just wondering if i have to change the sensors and anything else.
https://acurazine.com/forums/showthread.php?t=856844
Good Luck!
Thanks so much this was a great help. the part in the manual that scares us the most is.. "Remove the exhaust" they make everything sound so danm easy...
Old Jul 9, 2012 | 10:07 AM
fsttyms1's Avatar
There arent sensors. The base trans has the variable assist unit that is in the trans and has 2 hoses that go to it. You will have to get rid of a couple lines. The pumps are the same, they dont have sensors either
Old Jul 9, 2012 | 04:33 PM
When you have completed the repair, update this thread with your impressions/tips/short cuts that help you get through.
Good Luck.
rockyboy
Aug 4, 2024 10:35 AM
TL-Rocket
Apr 29, 2023 02:33 AM
Feb 25, 2020 09:57 AM
mike from annapolis
May 7, 2017 08:21 PM
asahrts
Sep 4, 2015 05:55 PM
