Power Steering problem...searched cant find answer
Old Aug 11, 2011 | 06:27 PM
SL03TypeS's Avatar
8th Gear
ok so i have an 03 TL-S. it was making a grinding noise coming from the power steering so i figured the bearing was goin bad, at this point i still had power steering just had the annoying noise. i didnt want to hassle with rebuilding the one in it so i bought a new one installed it made sure the belt tension was correct & it had correct amount of fluid in it. but when i try to bleed the system, the steering is now stiff & even after several turns from left to right it remains stiff & the fluid reservoir is bubbling also fluid shoots out the reservoir when you turn the wheel til contact then release. anyone know why this could be happening? any solutions? thanks
Old Aug 11, 2011 | 06:31 PM
SL03TypeS's Avatar
8th Gear
Power Steering Problem...searched cant find answer
ok so i have an 03 TL-S. it was making a grinding noise coming from the power steering so i figured the bearing was goin bad, at this point i still had power steering just had the annoying noise. i didnt want to hassle with rebuilding the one in it so i bought a new one installed it made sure the belt tension was correct & it had correct amount of fluid in it. replaced hi pressure hose o-ring. it got rid of the noise but when i try to bleed the system, the steering is now stiff & even after several turns from left to right it remains stiff & the fluid reservoir is bubbling also fluid shoots out the reservoir when you turn the wheel til contact then release. anyone know why this could be happening? any solutions? thanks
Old Aug 11, 2011 | 06:46 PM
Karanx7's Avatar
Unregistered Member
Air is still being introduced into the system. Where did you buy a "new" one?
Karanx7's Avatar
Unregistered Member
No need to make 2 threads for 1 problem.
Old Aug 11, 2011 | 06:50 PM
SL03TypeS's Avatar
8th Gear
i got it from napa its a "reman" i got it from there because i get a nice discount from them. do you think there could be a problem with it? should i buy an OEM one?
Old Aug 11, 2011 | 06:52 PM
SL03TypeS's Avatar
8th Gear
sorry new to this forum forgive me. i thought i didnt post the first one in the right place
Old Aug 11, 2011 | 07:07 PM
Karanx7's Avatar
Unregistered Member
Yea, it's probably better here, but I read that one first lol. Idk if they'll get merged or one will get closed.
Old Aug 11, 2011 | 07:10 PM
Karanx7's Avatar
Unregistered Member
New OEM ones are crazy expensive, so probably not. I had the same problem, and I replaced the pump with a OEM one from a salvage vehicle for ~60 bucks.
If your PS reservoir is still bubbling a lot, then you have to find the source that air is getting in. If steering got worse after you replaced the pump, then it's likely that the re-manufactured pump is bad.
Double check the rubber hoses, just to make sure it's not a clamp or something. If everything else is OK, try to get another pump if you got a warranty with it.
Old Aug 11, 2011 | 10:40 PM
my.daily'tl''s Avatar
Always Working In
^Same here. I had that awful bearing noise too. I got one from a yard @ 65 bucks and im good now. You need to make sure your pump is good.
Old Aug 11, 2011 | 10:41 PM
Always Working In
And mine decided to act up after my valve job this weekend smh
TL-Rocket
Apr 29, 2023 02:33 AM
Yikes
May 3, 2021 04:29 PM
mike from annapolis
May 7, 2017 08:21 PM
nash3222
Sep 10, 2015 09:46 PM
