power steering problem
Old Jul 13, 2012 | 05:59 PM
ArTL-S's Avatar
I have dead hookers in
Exclamation power steering problem
So i just got done doing a valve adjustment on my 02 TL-S and that went off without any issues until i got everything back together and turned on the car. For some reason now whenever i turn my wheel the power steering pump whines and it spits PS fluid all over the place from the resevoir.
Any ideas what could be causing this?
Old Jul 18, 2012 | 04:16 PM
closetprisoner's Avatar
2000 Acura TL
you have air pocket in the PS system.. remove cap turn wheel side to side.. turn it all the way and return..
Old Jul 19, 2012 | 11:50 AM
TLer trash's Avatar
You probably brushed up against the p/s pump. If you so much as look at them the wrong way you'll need a new p/s pump inlet o-ring. It's a cheap, easy fix, and a real common problem when you do any work in the vicinity of the pump.
TL-Rocket
Apr 29, 2023 02:33 AM
Yikes
May 3, 2021 04:29 PM
mike from annapolis
May 7, 2017 08:21 PM
nash3222
Sep 10, 2015 09:46 PM
