Power Steering leak?
I found a leak on a 2002 Acura TL, if your facing the front of the car there is a leak i believe is the is in the location of the gearbox and valve body unit but i am uncertain. Not sure what this is or called, I need help identifying this. Power steering res was a little low, the leak was right underneath list location and it was a nice size puddle.
Could it just be the hoses going into that have a problem or is there a seal inside that thing? I attached some pictures to what i am talking about.
I would appreciate any help, this is my daughters car so i would like to fix asap but need some information.
is the rubber hose in the pictures the Speed Sensory Inlet hose? looking at the diagram online can't tell if that is the inlet hose or the Speed Sensor Outlet tube. I believe this is where the leak is coming from.
