Power outage!! Please help!!
Old Dec 26, 2006 | 05:49 PM
MadHatter's Avatar
Smoke something...
I have a 2003 TL (non Type-S)... and I have a problem that I need some help with. The other day, I got in my car and realized that my interior dome light didnt go on when I opened the door. I figured the bulb burnt out and I'd replace it the next morning. Well, I tried changing the bulb and that wasnt the problem. Later that day, I noticed that my "seat position memory", and my passenger side seat heater also didn't work. I checked my fuses, and they all seem to be good. Has anybody had this problem/heard of it? The last thing I wanna do is take it to the dealer because I know I'll get charged an arm and a leg. Please help!!
-Mad Hatter-
Old Dec 26, 2006 | 08:45 PM
Malayalee King's Avatar
ഥഎണഡഏ Fellas Inc.
Have you checked every single fuse and not just the obvious ones?
Does the memory not recall the seats or does it not allow you to store them anymore either?
Does the map light come on?
Old Dec 26, 2006 | 11:03 PM
MadHatter's Avatar
Smoke something...
The lights on the seat memory arent even lit. When I push the buttons nothing happens. The map lights work... and I checked every fuse on that panel. According to my owners manual, the only fuses that have anything to do with my heated seats/interior lights are on the drivers side kick panel... Should I check the other panels too?
Old Dec 26, 2006 | 11:09 PM
Trackruner228's Avatar
Honestly it could be a concidence. Maybe your memory seat isnt programed right? Also maybe it wont move since its already in the right position? Also a lot of people have problems with there seat elements going out it seems to be common. Now I would assume that if the passanger heater seat didnt work because of a fuse that the drivers side wouldnt work either. Also I would think the memory seat would be on the same fuse as the power seats. So maybe just 3 seperate problems?
Old Dec 26, 2006 | 11:39 PM
MadHatter's Avatar
Smoke something...
the memory seat thing isnt even lit up anymore like it used to be. i dont know if the seat heaters both work off the same fuse, or if they use individual ones... looks like im gonna have to take it to the dealer
Old Dec 26, 2006 | 11:48 PM
Well how many miles are on it maybe it will be under warranty?
Old Dec 27, 2006 | 03:34 AM
Leo Type-S's Avatar
03' NBP TL-S
that is weird. if it's covered under warrenty just take it to the dealership.
Old Dec 27, 2006 | 08:40 AM
mezzerTL-S's Avatar
New ride...Acura MDX 2013
[QUOTE=MadHatter]The lights on the seat memory arent even lit. When I push the buttons nothing happens. The map lights work... and I checked every fuse on that panel. According to my owners manual, the only fuses that have anything to do with my heated seats/interior lights are on the drivers side kick panel... Should I check the other panels too?[/QUOTE]
yes you should, however in my owners manual (page 300)all the fuses for the heated seats and map lights are in the passenger side fuse panel, btw what year is your TL?
Old Dec 27, 2006 | 09:22 AM
ഥഎണഡഏ Fellas Inc.
sometimes when you d/c the battery, the memory seats need to be reprogrammed (1) adjust seats, 2) hit red button, 3) hit 1 or 2 memory position).
I would check to see if you could reprogram it first
[QUOTE=mezzerTL-S]
^ check passenger side first.
good luck
Old Dec 27, 2006 | 10:02 PM
MadHatter's Avatar
Smoke something...
i have an '03'.
I have the day off of work tomorrow, so i'll be able to dedicate more time into looking around and seeing if its anything obvious... if i cant figure out what it is, im gonna have to take it to the dealer. i'll keep you guys posted as to what happens.
- Mad Hatter -
Old Jan 2, 2007 | 09:02 AM
acurabum's Avatar
Make sure that your outside mirror adjustment 's button is in the middle position ...........
Acura604
20
Aug 5, 2017 12:55 AM
spudweb
May 22, 2016 02:39 PM
knight rider
Mar 4, 2016 08:59 AM
mars
Sep 28, 2015 11:03 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
