Please Help Im Stumped
Old Sep 16, 2013 | 06:14 PM
castls's Avatar
BANNED
on my 99 TL after a recent stereo install I lost my dash lights, all wiring is fine except I have 2 orange with white striped wires labeled dimmer and one from the metra harness thats orange labeled immuination the dimmers are wired up good, the small light and #9 fuse are brand new and not blow yet still no lights, in a older thread I read that a user grounded the illumination wire to the ground wire and it works but each time i do that I blow the small light fuse. Please help its been over a month now and i have tried 1000 different things.
Old Sep 17, 2013 | 09:27 AM
fsttyms1's Avatar
What happens when you disconnect the harness from the radio? Do you get your lights back?
Old Sep 17, 2013 | 02:15 PM
castls's Avatar
BANNED
Ill give that a try tonight, I blew the Small Light fuse again last night. After wiring both dimmer wires I was able to keep my odometer and SS light illuminated but no dash lights... Ill take that as a good sign since before hand when I turned the headlights on it would all go black. I dont get why I have only 1 illumination wire from the metra harness with no wire for the radio yet I have a dimmer on both. This blows. Lol.
Old Oct 3, 2013 | 02:30 PM
castls's Avatar
BANNED
Someone please is still no dash lights. My taillights work as well as my turn signals but no dash. Radio dims when i turn the head lights on but nothing else.
Old Oct 3, 2013 | 03:39 PM
fsttyms1's Avatar
There should only be 1 dimmer wire connected. like I asked before, what happens when you disconnect the harness. Do your dash lights work?
Old Oct 3, 2013 | 09:26 PM
Cyro22's Avatar
I recall its the orange wire and not to use the orange/white wire. Chris.
Old Oct 4, 2013 | 09:55 AM
castls's Avatar
BANNED
sorry, I unplugged it and still nothing it seems, i got them to work for a split second, then the small light fuse blew.
Old Oct 5, 2013 | 03:01 PM
castls's Avatar
BANNED
Still no lights...with harness unplugged and even with stock radio back in. pleeease. All fuses have been replaced.
Old Oct 6, 2013 | 02:06 PM
fsttyms1's Avatar
So with everything hooked up back to stock, it still doesnt work AND does it still blow the fuses?
Old Oct 7, 2013 | 09:47 AM
castls's Avatar
BANNED
Correct with the radio out even with the stock re plugged in and fresh fuses still no lights, the Odometer light stays illuminated until i switch my lights on and it too goes black. If it helps I have a pioneer 6 inch double din, dvd bypass, a 500 watt alpine amp and Type R sub woofer. I had this problem a long time ago and it ended up being the small light fuse now it seems it not a fuse isssue. I did the Blue Led cluster swap last year could i have possibly shorted out the LEDS themselves?
Old Oct 13, 2013 | 02:06 PM
castls's Avatar
BANNED
bummmp
Old Oct 14, 2013 | 02:18 PM
castls's Avatar
BANNED
No longer blowing fuses, I have the illumination wire and both dimmers undone and nothing at all light wise. Could the leds possibly blown or shorted out when I was experimenting with the illumination and dimmers?
Old Nov 15, 2013 | 05:01 PM
castls's Avatar
BANNED
buuuump fuuuck this is the worst. re wired radio nothing read i should ground the illumination wire to the ground wires and boom blown fuse.
Scribesoft
Home & Garden
30
May 3, 2006 12:25 PM
zeroday
Home & Garden
Aug 7, 2005 09:52 PM
BigPimp
Money & Investing
24
Apr 14, 2005 01:41 PM
