passenger seat slide not working.
Did you get this problem fixed? i have the same problem with my 2000 TL. looks like a wire is disconnected but I cant see under the seat enough to find where it goes. Did you remove your seat? If so... how? If not, then how did you fix the problem?
the car wash people moved my girlfriend's passenger seat all the way up. it is stuck in the all the way forward position, so it's impossible to remove the bolts easily.
the seat won't move back on one side. it seems like it derailed itself. is there any way i can fix this easily without it getting serviced at the dealership or mechanic? i don't want to burn out the motor. the mechanic that took a brief look at it said he'd charge $150 just to take it off to look at it. thanks much!!!
Awesome. I'll give it a look tonight. If it's broken or damaged, how could I get the part number? Or should i just be able to fix it with some pliers and electrical tape?
Use this link, plug in the required info for model and year and go to the part ou are looking for parts for (ie front pass seat)
http://www.acuraautomotiveparts.org/...catdisplay.jsp
I've got a similar problem. My seat will not slide forward or backwards. I looked under the seat for pinched wires or any connection problemsbut saw nothing out of ordinary.
There was clicking coming from the brain? Any suggestions?
i never got it to work. i looked under the seat and everything looked normal. i'm resigned to the fact that i'll have to take it to a mechanic eventually. i don't even know how he'll get the seat off, since it's all the way up. car wash people must have dislodged something or messed something up when they were vacuuming.
mlody
Dec 4, 2019 02:11 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
