Passenger HID out
Old Aug 22, 2010 | 07:21 PM
StLAcura's Avatar
Passenger HID out
Hello, new to the page with a question i have seen before. 1999 TL, 263xxx miles, clean daily driver. Factory HIDs, passenger side going pink/ purple. Ordered 8K HID bulbs, installed (small pain in ass) and that night, passenger side will not come on. Bulb? Ballast? Ignitor? I have seen on the forums and threads that this is an issue and I would appreciate any help/ suggestions with this issue. Thankyou for everyones time, and I look forward to a future on this site.
Old Aug 22, 2010 | 07:59 PM
01tl4tl's Avatar
swap the bulbs left to right and see if the problem follows a bulb
dont expect to see much of the road with 8000--those are basically purple
Old Aug 27, 2010 | 10:51 AM
xabiostayler's Avatar
After doing what the previous post suggested if you find that is the ballast make sure you buy the acura one.(you can find them in ebay at about 100-150$). i had a similar problem i bought an aftermarket ballast and it made the problem worst. I agree 6k is the most i would go.
Old Aug 27, 2010 | 11:44 AM
richardparker's Avatar
3.7L Nitrous Breathing CL
So after the chaging the bulb it will not come on ?
the coloring of the bulb,does usally mean a bulb.
If it's not lighting may be a bad ballast.
Also if it's not lighting.check your headlamp fuses under your hood.
A bad ballast will keep blowing fuses.
MilanoRedDashR
Oct 8, 2015 10:30 AM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
rhdune16
Sep 28, 2015 11:31 AM
MilanoRedDashR
Sep 27, 2015 10:15 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
