P1753 Code After 1999 3.2 TL Sits 10 Days
Old 07-11-2016, 02:08 PM
4th Gear
Sturmgewehr44's Avatar
Normally fully reliable 99 3.2 TL that I purchased new has 104K on it threw P1753 code when I went to leave for work this morning. Car wouldn't move in D4 but has reverse. Code states "Automatic Transmission Lockup Solenoid A Malfuction." Just looking to see if someone else has had a similar situation and might be able to help.
Old 09-12-2016, 11:49 PM
coug66's Avatar
Whats the status? the lock up solenoids on ebay are like $25 each shipped. Not a big investment to swap them out.
You are probably past that now what was it?
Old 09-13-2016, 05:08 PM
Mr.Helpful Diagram
ErickUa5's Avatar
Test the solenoid first before replacing, By adding 12 volts to the wire and listening for a click.
If it does not click then the solenoid is no good.
Is the D4 light blinking before starting the engine ? If so its definetly a wiring problem, Since you mentioned the car sat for 10 days it may be possible that mice chewed up the wiring to that solenoid.
Flipster23
Norcal
262
05-04-2023 02:47 PM
EE4Life
12-20-2022 05:16 PM
EE4Life
03-12-2020 07:29 PM
Alex D
06-29-2016 07:38 AM
EE4Life
05-14-2016 07:14 AM
Quick Reply: P1753 Code After 1999 3.2 TL Sits 10 Days
