P1676 and P0401 CEL
Old Jan 8, 2008 | 03:21 PM
rvl123's Avatar
Exclamation P1676 and P0401 CEL
Hey everyone, I am getting the 1676 and 0401 CELs and was wondering what the fixes are for these.
I tried one of those fuel system cleaner things for the p0401 (EGR valve) code but I doubt that that will fix it.
Thanks!
Old Jan 8, 2008 | 03:48 PM
fsttyms1's Avatar
Thanks!
You have to remove the upper intake and manually clean the ports out. Look in the DIY thread for instructions on cleaning it
As for your other code?? it sounds like there may be a short in a sensor or the wiring between the trans and the ECU
Old Jan 8, 2008 | 04:16 PM
rvl123's Avatar
I found this: http://www.in.honda.com/Rjanisis/pubs/SB/B00-004.PDF but it's hard for me to figure out stuff without actual pictures of the components.
and there was another thread that I found but all the pictures were missing so it was useless. Is there any other DIYs that have pictures floating around?
Thanks!
Old Jan 8, 2008 | 07:09 PM
fsttyms1's Avatar
Thanks!
Its the upper Intake Manifold. Its what you see when you open the hood. You remove teh plastic cover and its under that.
What year do you have?
Old Jan 8, 2008 | 07:41 PM
spiro's Avatar
https://acurazine.com/forums/showthread.php?t=156252
Old Jan 8, 2008 | 10:58 PM
rvl123's Avatar
I have a 99 TL-P
Old Jan 9, 2008 | 07:36 AM
fsttyms1's Avatar
Look at the link above your post
Old Jan 9, 2008 | 02:00 PM
rvl123's Avatar
wow took off the IM and looked at the EGR port and it was completely shut with gunk. Cleanin it out now and putting everything back. thanks!
now to just figure out which wires are out of place...
Old Jan 10, 2008 | 09:40 AM
rvl123's Avatar
hmm, the 1676 code went away but the 0401 code came back on. maybe i didn't clean it well enough or maybe it's the physical valve that's clogged. where is the valve exactly?
Yikes
May 3, 2021 04:29 PM
heykosal
1G RDX DIY & FAQ
Nov 16, 2020 03:59 PM
NJALLDAY57
Oct 13, 2015 08:25 AM
samson_420
Oct 8, 2015 01:47 AM
hrothgar02
Sep 28, 2015 11:08 AM
