P1456 or P1457
Old Jul 23, 2012 | 11:08 AM
djescobar973's Avatar
Keep it flush!
P1456 or P1457
Whats up Aziners.. I went to my local Autozone to buy a few things, my CEL has come on in the last few days and they loaned me the diagnostics tool. I believe the code they came back is one of the 2 below. For some reason I only took down 3 of the numbers but they def were 145... Anything I should be looking for, try...?
P1456 Evaporative Emission Control System Leak Detected (Fuel Tank System)
P1457 Evaporative Emission Control System Leak Detected (Control Canister System)
Old Aug 3, 2012 | 08:30 AM
3.2TLc's Avatar
P1456 / P1457 codes
Have the codes pulled again. The 1456 could be as simple as a loose or faulty gas cap. The 1457 is more involved, most of the time being the evap purge cannister and purge valve located under the driver's side rear wheelwell area. A search will give you more specific info and pics. Good luck !
Old Aug 3, 2012 | 10:21 AM
01tl4tl's Avatar
do you top off the fuel tank in hot weather,,that will kill the evap cannister
Old Aug 5, 2012 | 12:45 AM
3.2TLc's Avatar
evap cannister
The cannister along with all of it's attached plumbing of hoses and electrical connections for the valving all basically "suck" ! That's their primary task which the emission system was designed to do for our cars. The location of the apparatus exposes it to all kinds of brutal conditions. I'm surprised that they even work as well as they do after 10 years of abuse ! Has anyone come up with a way to get around this ?
Skirmich
Oct 1, 2015 12:59 PM
DS2000TL
Sep 9, 2015 09:26 PM
Trader122312
Jul 23, 2015 02:31 PM
johnpancakes014
Jul 17, 2015 07:18 PM
Chr8808
Feb 21, 2007 07:54 AM
