P1298 ELD high circuit input 99 TL
Alright so.....this ELD (Electrical Load Detector) CEL code came up recently and I spent hours trying to figure out what to do. I googled and found plenty of Civics with this problem. The thing about the Civics with this problem is they can replace the ELD itself. Our 99 TL unfortunately does not work that way. The ELD is built in to the under hood fuse box. With that being said, the forums said to just replace the ELD, but since our TL has the whole fuse box, I decided to just buy the fuse box and hope for the best. I actually experienced random car shut-offs with this code, but I am also experiencing the ignition switch recall issue atm. I noticed MORE random shut-offs with this ELD CEL code. Anyways, here we go....
Tools required: PATIENCE basic tools This job is tedious and a little frustrating. Part number: http://imageshack.us/a/img689/8389/img1039cl.jpg This is the new fuse box, notice the black piece underneath. It pops off and the wires are all nice and neatly protected by this piece. The issues you will have with this job is trying to remove that piece while it's still on the car, and unplugging the plugs while it's still on the car. There are about 3-4 plugs under there which you need to disconnect: http://imageshack.us/a/img837/2083/img1026cj.jpg This hole is where the wires go through and plug up under in there (This is one of the reasons it is tedious): http://imageshack.us/a/img687/3332/img1025pd.jpg First, disconnect the 2 cables on the side of the fuse box and the clip right there next to the cables: http://imageshack.us/a/img824/3271/img1024qu.jpg http://imageshack.us/a/img842/5714/img1031w.jpg Now, there are 2 clips on the back of the fuse box which need to be released from the frame of the car. You just need to lift them and lift up on the fuse box and poof! It's off....the frame: http://imageshack.us/a/img842/5714/img1031w.jpg Another angle of the rear of the fuse box: http://imageshack.us/a/img94/9011/img1030qg.jpg Now, I don't have a pic of the underside of the fuse box with the wire protector/cover off. Try to read my mind...The under cover just pulls off, con huevos. Once you remove that cover, you need to disconnect the 3-4 plugs underneath the fuse box. There is some slack in the wires, but not that much, so don't pull too hard. Once it's out, you should have this (This is showing the plugs and the frame where the back of the fuse box is clipped to it) http://imageshack.us/a/img12/1339/img1029qz.jpg And here is another angle of the plugs: http://imageshack.us/a/img690/8086/img1028ts.jpg Here's the new fuse box next to the old one: http://imageshack.us/a/img201/5656/img1037ff.jpg The new fuse box comes with all new FUSES ONLY, it does not include any relays. That would have been cool if it came with all the relays too, but hey...it is what it is. You do need to reuse your old relays when you install the new fuse box. When installing the new fuse box, the best way to do it is 1st plug in all the green plugs underneath 2nd put the new undercover back on (you have to make sure you have all the wires inside the cover WHILE you're putting it back on, and with the little slack that you have) 3rd clip the fuse box back to the frame of the car Lastly, reconnect the 2 cables on the side and plug the electric white plug back in. The 2 cables only go in 1 way, they have a little guide to ensure it goes in and stays in. The white clip also has a little guide for the wire. Don't miss these when working on it. Besides that, you're good to go. CEL light went away and no more ELD code! I hope this was helpful for you guys! I hope this gets added to the DIY section for easier searching and help! |
Great write up.. so how much does the new fuse box cost ??
Originally Posted by closetprisoner
(Post 14330078)
So did the box fix your problems ?
'99 TL's had ignition switch issues, so make sure that's operating properly. The fuse box hasn't been a big problem with the TL's. Isn't the ELD circuit relay a replaceable part by itself ? Good DIY if one has reason to do it. Check wiring connections and grounds first ? |
Originally Posted by 3.2TLc
(Post 14330896)
:thumbsup:
Ttt
Mod edit: P1298 ELD high circuit input 99 TL DIY Fix
Add my DIY's to the list! PLEASE! |
Originally Posted by emaka9
(Post 14350782)
