p0730 P0710
p0730 P0710
Just got check engine light
I'm not positive but Problem seems to be slipping in gear 3/4
Codes
P0730 gear ratio incorrect
P0710 transmission fluid temperature sensor circuit malfunction Sensor A
FYI it is 4 degrees Fahrenheit here today.
Codes
The D5 is not blinking, but trans is slipping bad, thinking about 3x3 transmission fluid change, but I don't have the time so may bring it in, not sure what that will cost and if its worth it. In the meantime I think I made a mistake by putting Lucas Oil trans fix stop slip in
I think at this point in time anything you do is not going to help. Your transmission will need either rebuilt or you need to get an AV6 swap.
The sooner you fix the issue rather than try a bandaid fix, the sooner you can start driving your car again.
