Oil Pressure Issue
2003TL-S with Accord Swap
Not something I was trying to do. After finishing installing valve cover gasket. I ran the car, walked away for 3 minutes car was off. Turned back on oil light was illuminated. That was the test that was performed to see why there was no oil getting to the top of the motor.
justnspace (04-22-2014)
3.2TLc (04-23-2014)
Mr.Helpful Diagram
Since the engine is cold you might not be able to tell the correct oil level but either way check it.
Does it show anything on the dipstick ?
Yeah, ya may wanna just start over fresh, with draining the old oil and replacing it with 5 qts. of new oil and filter. Recheck all past work. Could be something simple.
It seems strange that this situation just reared it's head shortly after replacing the valve cover gaskets. Perhaps something is loose or not properly connected after the previous repair work. Check over everything and try what TLer trash suggested previously. Ya may get lucky !!!
The original issue with the car was the 1399 code. Figured out it was the coil or spark plugs, not sure which on was the issue, all were replaced. Stsrted car all was good. The car performed like a champ. Than replaced the oil pan, because the drain hole was damaged. Started car, car ran perfectly. Was going to replace timing belt and water pump, due to car having 171k miles, upon opening up the timing cover everything looked good. I than replaced the valve cover gasket because it was leaking. After this installation the car had the oil pressure issue.
Make sure you got the right pan. There's a spit somewhere between 99 an 03, and the wrong pan is too shallow. It covers the sump inlet completely, not allowing any oil to get to the pump. If I can get more specific info, I'll post it later.
While they fit, and they look similar for some reason they arent.
Type-s is on the left
mada51589
05-03-2022 08:54 PM
IIDXholic
10-08-2015 07:53 AM
NBP_BALLER
09-23-2015 08:18 PM
