Odd Buzzing sound while accelerating
Old Oct 13, 2011 | 11:19 PM
Blkjag09's Avatar
Exclamation Odd Buzzing sound while accelerating
Hey,
I really appreciate anyone who takes the time to help me out with this..
I have a 2003 TL-S with 116k on it. Just bought the car two months ago. Trans was replaced through honda, have all the paper work...
So basically I realized that when u start the car and accelerate past 5mph it makes this buzzing sound for abt a second, than does it once again when u hit 10mph. on the first buzzing sound u can feel it in the gas pedal, kinda like a little vibration, second one u cant feel it at all.
This only happens when u start the car and drive... if u drive around and dont shut it off and than start to drive again it doesnt do it....
Anyone with a clue out there as to what this strangeness can b.. please respond.
Thank you all for your time
Old Oct 14, 2011 | 06:30 AM
BillThyCat's Avatar
I believe that is the ABS system doing a power on self test. Someone else will correct me if I am wrong.
BTC
Old Oct 14, 2011 | 08:15 AM
hANDYcaptd's Avatar
It's the Halladay season!
BTC
Correct. This is perfectly normal.
Old Oct 14, 2011 | 09:49 AM
01tl4tl's Avatar
I thought it was 5 and 15 but it definetly is the ABS doing its `first start of the day` self-test
register as a new owner with `acura care` and ask if all the recalls are taken care of
1 800 382 2238 x5 gets a human
also at www.owners.acura.com need VIN for both of those
You can download a free owner manual there, and safely store the radio/nav security codes for future referance = when the battery is changed
Welcome to the forum and its group of acura nuts!!
Old Oct 14, 2011 | 02:50 PM
Blkjag09's Avatar
Thank you all very much for your quick response.. i had an 01 Tl that never made that sound. So when i upgraded to the 03 i found it very odd that it was makin that sound.. ppl told me it might have something to do with a solenoid on the trans..
Old Oct 14, 2011 | 03:02 PM
Blkjag09's Avatar
Thank 01tl4tl.... i been an acura owner for the past couple yrs... been very happy.
First car was an 88 legend coupe.. That was the shit back than. car had 180k and still hit 60 in 6 sec
Old Oct 14, 2011 | 04:38 PM
01tl4tl's Avatar
now we use the front brake calipers for the 1995 legend,, as a cheap upgrade to dual pistons!
If its more than a quick noise at those speeds- there may be other things wrong,
a cv joint noise as you turn and back out of the driveway, or enter a dip from curb to street? never hurts to ck the brakes and nearby parts under the car
trees work as decellerative devices, but brakes are cheaper
Old Oct 14, 2011 | 04:45 PM
hANDYcaptd's Avatar
Old Oct 14, 2011 | 08:41 PM
Blkjag09's Avatar
Haha.... def would wanna end up in the trees..
Old Oct 14, 2011 | 08:42 PM
Blkjag09's Avatar
i had just recently replaced both axles as well as all 4 balljoints.. when i got the car i was kinda makin a creaking noise when u turn the wheel in either direction.
Old Oct 14, 2011 | 09:58 PM
01tl4tl's Avatar
may not have set the bolt torque correct on those parts
too tight when applied with air gun,
no torque wrench bringing them carefully up to spec~
Old Oct 15, 2011 | 01:46 AM
Blkjag09's Avatar
Would u know of a website that i can get the torque specs from so i can do it right, the mechanic that did it was using an airgun, so im suspecting that its def outta wack
mlody
Dec 4, 2019 02:11 PM
gatrhumpy
19
Dec 31, 2015 04:22 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
Skirmich
Oct 1, 2015 12:59 PM
mellsonnj
Sep 24, 2015 04:42 PM
