Not the same Transmission question
Old Aug 22, 2007 | 08:32 AM
Nesbitt01TL's Avatar
5th Gear
2001 TL.
Shifts fine through out all gears except starting off. If you just let of the brake and let it go then give it gas it works golden but if you push the gas anywhere over half on the start off there is a jerk to get going. Want to know if anybody else has this issue. Now this baby has 170K on it. I just took ownership from my father. It had the transmission replaced at 112K in 2004. Thanks in advance for any answers.
Old Aug 22, 2007 | 09:25 AM
Mike B's Avatar
That sounds like its the motor mounts which is common on our vehicles. I recently ordered all 5 motor mounts for $199 shipped from www.sonsacura.com I know I didnt need all 5, but just wanted to make sure.
Old Aug 22, 2007 | 06:45 PM
5th Gear
Just to clarify... If the motor mounts "went bad" what would the end result be?
Old Aug 22, 2007 | 07:18 PM
Mike B's Avatar
A bad motor mount will have the symptoms that you are describing.
You will only feel from the start. If you accelerate, you will hear a thud.
Old Aug 22, 2007 | 08:39 PM
5th Gear
Okay, that is pretty much what is going on. Thank you for your inputs.
Yikes
May 3, 2021 04:29 PM
pstomps
Feb 20, 2017 03:29 AM
BoricuaTL
Apr 8, 2016 01:08 PM
ghuns
Sep 16, 2015 04:26 PM
datadr
Sep 12, 2015 09:12 PM
