No more sound after battery change
Old Nov 2, 2008 | 05:52 PM
mocap3069's Avatar
4th Gear
I have a 2003 Acura TL Type-S and had to get a new battery. I put in the code after the battery was changed and the radio powers on but no sound. I have check all the relevant fuses and they are fine. Also the audio control on my sterling wheel does not work any longer. Any suggestions??
Old Nov 2, 2008 | 07:00 PM
fsttyms1's Avatar
Does the radio actually power up, like you can change radio stations and stuff??
I dont know of any reason it shouldnt work if it does. There isnt a separate amp for any of it. Check the 2 fuses to make sure (both are on the passenger side dash fuse panel)
Old Nov 2, 2008 | 07:18 PM
mocap3069's Avatar
4th Gear
The radio is fully functional and when I change tracks on the CD in the player I hear some weird sound coming from the rear speaker? What is the other fuse? I only looked at fuse 9? the one that says ACC/Radio.
Old Nov 2, 2008 | 08:02 PM
Rajca's Avatar
wham bam thank you ma'am
turn the volume up, lol. maybe something shorted
Old Nov 2, 2008 | 08:51 PM
mocap3069's Avatar
4th Gear
Funny!! I tried cranking it to the max and not so much as a static pop!!
Old Nov 2, 2008 | 10:06 PM
fsttyms1's Avatar
Check the i believe its the clock backup fuse. (its also listed in the manual)
Other than that i dont know what to say. If it powers up it should be working.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
Iain MacLeod
Sep 17, 2015 01:01 PM
Aleax
Sep 11, 2015 11:31 AM
sputik
Sep 7, 2015 01:40 PM
