new low beam bulbs
Old Oct 10, 2009 | 06:31 PM
blurrpleberry's Avatar
new low beam bulbs
i need a new bulb for my driver side low beam. what kind do i need that is cheap good quality and looks sweet/bright..............stockheadlights
Old Oct 10, 2009 | 09:33 PM
niju321's Avatar
first switch left and right bulbs to make sure the bulb is the problem, your ballast/igniter/misc HID electronics may be the problem
if it's the bulb, then you need to replace both of them at the same time
there are quite a few AZ vendors who sell good bulbs, can't remember all the names off the top of my head but i think some are hidextra, excelerate performance, etc. i would suggest you get 4300k bulbs for the most usable light...
Old Oct 11, 2009 | 01:00 AM
juanclopez2786's Avatar
check out the sponsored sales and group buy thread you can get good bulbs from hidextra i got them for low beam and the fog light hid kit.
Old Oct 17, 2009 | 11:50 AM
but if i switch the stock bulb over and that one goes out i have just fogs lights to drive with ha
Old Oct 17, 2009 | 12:56 PM
stock ballasts
is it possible that the stock ballast can tgive enough power to the 6000k bulbs i want to use.
Old Oct 18, 2009 | 02:07 AM
Gfaze's Avatar
S E L L
The amount of power they use is the same no matter which one you get. The 4300K, 5000K, 6000K, etc is just the color temperature, not the amount of electricity it uses. So yes, the stock ballast should be just fine.
Old Oct 18, 2009 | 07:45 PM
ballasts
where can i get a cheap ignitor and ballast i switched the bulbs and the bulb works on the good side i need a new ballast like 75% sure
Old Oct 18, 2009 | 07:46 PM
ballasts
where can i get cheap ballasts
hashbrown
Feb 18, 2022 11:20 AM
08KBP_VA
Oct 22, 2019 01:55 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
rockyboy
Sep 29, 2015 12:05 AM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
