need help trans no 3rd 00 tl
Need to know why I have no third gear and wen I first start it up p and n are both lit up also the brake light comes on what does that mean anyone? PLEASE!
B A N N E D
might just be an electrical issue too, but third gear is NOTORIOUS for going out on the 5-speed automatics (especially the first year, and your transmission has probably even been replaced before too under warranty
but basically what the lights mean is that there is a code in the ecu for the transmission, and basically those need to be checked with a scan tool
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
B A N N E D
as far as 6-speed, a transmission first of all, along with a clutch, and a manual starter
then also a bunch of other parts too; which are more then likely going to run well into the $4,000+ range (still cheaper to get a rebuilt auto though
btw search the forum for parts needed on the 6-speed swap
thats some odd lights to get--has the CEL or D5 light flashed on the dash?
can it make it to a parts store for a code reading?
ck the trans fluid -color and smell? burnt sugar smell = bad
current mileage on car?
ck trans bolts- are the heads painted blue- thats a warranty unit
there is a chance you may not have gotten the oil jet recall done
call acura 1 800 382 2238 x5, have cars VIN in hand- register as owner
and ask if all recalls are complete-
Your dealer can run the VIN for same info
can you get any gears to move the car-- or its dead in the water?
each gear shaft carries 2 gears, clutch wearout can effect many things
might be something simple like an external selenoid--have it looked at by a trans shop-
not aammm..we know their diagnosis
Is this a sudden problem- no signs of trans slipping or acting up at all?
Your trans is toast. It needs to be replaced.
flushed the trans- drain and refill or power machine flushed? honda atf?
if our mega trans gurus say its a real problem....
Im surprised the trans has held up this long in this condition of 3rd not working.
I suspect ~liberal use~ of SS was required to bypass the bad gearset/clutch.. and go right to 4th??
Hey - whatever it takes,,but
its the the kind of thing you might want to look into before a year goes by,,
when surprise surpriiiise,,the trans quits without warning!!
mlody
12-04-2019 02:11 PM
emailnatec
29
09-28-2018 04:27 PM
