NEED HELP! Camshaft/Crankshaft was moved without timing belt
I'm doing a timing belt and waterpump job, but when I was installing the new timing belt the rear cam was moved. I tried readjusting the cams back into place which I know they arent suppose to be moved without timing belt on, but I figured a little tweak of an adjustment wouldn't be too much. Now, Ive hit a major road block because instead of a little tweak, I managed to turn the front cam 4 full circle and the rear cam in 1 full circle and not sure how many times ive turn the cam shaft. What is the best way to go about this? or how do I make sure that the cam shaft and valves wont hit with the pistons?
PLEASE HELP I OWN AN 2003 ACURA TL TYPE S
Hi xryanbe12`
Here is the procedure to get everything lined up.
After reattaching the crankshaft pulley with your belt on, turn it clockwise about 5-6 turns and then align the white mark on the pulley so it aligns with the triangle pointer arrow.
Then check the cam pulleys and make sure that their markers line up (through the little window on the pulley covers). If they don't line up at TDC then pull it all apart and start over again. Good luck.
Something I was wondering about, as I've never had this problem before - if your timing is incorrect during this procedure, and a valve strikes a piston head while you're manually turning a camshaft, can you safely continue to move the cam through the strike? Or would you turn the cam backward to avoid the strike?
mcfly_
10-21-2015 07:22 PM
