My TL "wobbles"
Old Nov 23, 2008 | 02:44 PM
arsenal5813's Avatar
My TL "wobbles"
My 2003 TL tends to "wobble" when going 50mph and under. It's mostly in the front on the passenger side. I have had my Acura dealer check it out, they found nothing wrong, I recently got new tires, but I still notice this "wobble." Any ideas on what it might be? Thanks!!
Old Nov 23, 2008 | 03:08 PM
mge2790's Avatar
alignment or balance of your tires might be off
also check the tire pressure, especially in the front 2 tires
Old Nov 23, 2008 | 03:16 PM
MichiganRich's Avatar
I had a wobble in the passenger rear that was so bad I thought it was a bearing. As soon as the dealer replaced the tires and aligned and balanced them it was dead smooth again. I will never discount the importance of a really good A/B service on new tires again.
Old Nov 23, 2008 | 08:44 PM
I have had them aligned and balanced lots of times, it only goes away for about 2 weeks then it starts wobbling again, i regularly check tire pressure also, no difference
Old Nov 24, 2008 | 08:11 AM
JDM Inspired's Avatar
I have the same problem when doing 40 the car would just shake in the front.......and if you checked all your tires with the pressure and that was fine, it could be your axle
