Most common front suspension problems:
Old Apr 25, 2011 | 11:52 PM
Jimmmmbo!'s Avatar
Brain donor
Hi everyone:
I have a 02 TL-S at 98K that is starting to give up some really nasty front end clunks and thumps here in pothole / sand-salt Minnesota. From what I can tell, the CV and tie-rod boots are all in pretty good shape.
I'm wondering what tends to be the most common front suspension repairs / replacements made to a stock TL-S at this point in life. I want to keep my car for another 2-3 years at least, but don't want to destroy my front suspension, or put up with the noise in the process.
Help???
Old Apr 25, 2011 | 11:54 PM
03tLsNBP's Avatar
MechEng
my lower ball joints became a problem at 103K.
Old Apr 26, 2011 | 12:55 AM
03tl-s04mdx's Avatar
^ +1 - front lower ball joints at 78K last year.
Old Apr 26, 2011 | 01:16 PM
fsttyms1's Avatar
Lower and upper ball joints, swaybar end links and shocks are what typically cause it. My upper control arm bushings were teh cause of it once.
Old Apr 26, 2011 | 04:43 PM
gold2003tl (90)'s Avatar
2003 TL-p
i had an upper control arm bushing pop out on me once, made a constant clunk on the way home......
Old Apr 26, 2011 | 10:39 PM
jsirious's Avatar
Front lower ball joints and sway bar end links with me.
Old Apr 27, 2011 | 10:51 AM
ANC297's Avatar
Bonki' Ehrite!
Sway bar endlinks...Blown strut....And bump stops as well.
Old Apr 27, 2011 | 02:56 PM
smartypants's Avatar
I just changed an outer tie rod end and a sway bar link. My 99 has 86K miles.
I was getting a vibration when braking at high speed and assumed a warped rotor. When I went to take off the off the wheel, there was about a quarter of an inch of side to side "free" play in the wheel. Took off the wheel and not only found a bad tie rod end but also the sway bar link was broken off and no longer attached to the car.
Needless to say, I was not pleased......
Old Apr 27, 2011 | 09:41 PM
Jimmmmbo!'s Avatar
Brain donor
Thanks for all the replies. I had my mechanic tell me several months back that he thought that my lower ball joints were going bad. Before I let him go in there, I'll check to see if these other things may also need to be looked at.
Thanks, everyone.
Jim
Old Apr 27, 2011 | 10:47 PM
jsirious's Avatar
Best of luck Jim... and keep us posted!
marcelft
Jul 10, 2018 06:17 PM
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
Heyzuez20
Oct 14, 2015 07:18 AM
08 NBP TL
Sep 8, 2015 08:49 PM
nuldabz
Sep 3, 2015 05:49 PM
