moisture in drivers headlight
Old Dec 2, 2013 | 09:26 PM
jim c's Avatar
5th Gear
Exclamation moisture in drivers headlight
my headlight has moisture in it and it doesnt seem to want to dry up the headlight blew ,and now i have to change it ! how do you take off the bumper ;so i can dry it out and replace the bulbs
Old Dec 2, 2013 | 10:38 PM
Skirmich's Avatar
Ermmm you don't have to take the bumper to replace the bulbs.. The bulbs are changed from inside the engine bay.
The Low Beams are D2R and require a Security HEX to remove the cover.
The High beams are 9005 and can be easily removed.
Old Dec 2, 2013 | 10:51 PM
TLin401's Avatar
'13 Hyundai Sonata
Your headlight could be damaged or the seal is broken. You could repair if you wanted to try it yourself. You just need to reseal the light if it's the seal.
Old Dec 3, 2013 | 06:33 AM
3.2TLc's Avatar
Welcome Jim c !!!
Moisture in our headlamps is a rather common issue. The affected headlamp assembly will need to be resealed or replaced. Many other owner's have converted to aftermarket HID replacement kits. These kits feature new technology, being less expensive and water resistant.
For more detailed info on HID problems and fixes.....check the 2nd Gen "DIY" sticky or search the many previous related threads on the subject. Good luck !!!
BoricuaTL
Apr 8, 2016 01:08 PM
scionxb3003
Oct 2, 2015 05:50 PM
pistacio
Sep 26, 2015 09:45 AM
acuraST
Sep 17, 2015 02:31 AM
JnC
Sep 11, 2015 06:06 AM
