Misfire with no codes.
Hello, my 03 TL type s has 203xxx miles. I've been having issues with it misfire randomly. So far it's happened at startup when it's already warm. And it almost wants to die if I come to a quick stop. But it always corrects it's self right away. Dosent do it every time. I've done the spark plugs and an oil change but it's made no change that I can tell. But the weirdest thing is it never sends any codes. But it's an obvious misfire in one or more cylinders. I step on the gas to keep it alive and it'll go away after about 30-60 seconds and run fine after. Possibly clogged injectors? Coil packs? There is a small amount of valve lash that I need to go to Honda for because it has v tech and I don't wanna fuck it up. Anything helps. Thanks.
