Metallic/grinding noises
Old 04-06-2012, 06:47 PM
3rd Gear
rajp's Avatar
Hi
I have a 2000 acura tl with 192K miles on it. The transmission has about 100K miles on it. Of late i have been hearing metallic grinding kind of noises from the front of the car seemingly from the under-side.
The noise is present when i start the engine and thru 1/2nd gear. It goes way as i speed up. the noise stays even when the transmission shift lever is in 'P'.
I do suspect the grinding noises to be the transmission. I got it checked by a mechanic who said the transmission is ok but it is actually a noise from "loose substrate" in the catalytic converter. The cat did throw the P0420 code. However currently the check engine light is off, for the past few days.
How can i know for sure the noise is loose substrate from the cat and NOT the transmission?
Thanks.
Old 04-06-2012, 11:20 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
jack the left side of the car up and support
bang on the bottem of the cat with your hand or a soft mallet
if it makes loose rock noises.. its bad
A muffler shop will usually test it for free- with the same banging plus a pressure/flow rate and temp test if needed
ck our vendor Excelerate for excellent deal on replacement units
MrHeeltoe
20
02-23-2023 01:54 PM
SexyRL
4G TL Problems & Fixes
08-19-2016 10:03 PM
xsilverhawkx
10-05-2015 11:00 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: Metallic/grinding noises
