the metal bracket holding coolant reserve tank
Old 08-24-2012 | 11:15 PM
jliu6789's Avatar
the metal bracket holding the coolant reserve tank is rusty and broken; the coolant reserve tank fell down the gap. I temporarily tied the tank to the wall of battery.
does anyone know how to get the replacement part for metal bracket ? it seems to be a part of assembly under the battery box.
it is for 2001 Acura TL.
Old 08-25-2012 | 12:07 AM
01tl4tl's Avatar
ck your local junkyard, now called auto dismantler and recycling
or be happy with zip ties and gorilla tape--it wont go anywhere
Old 08-25-2012 | 08:17 AM
fsttyms1's Avatar
its part # 60630-S3M-A00ZZ, BATTERY Base, 2001 TL $12.55
http://www.acuraautomotiveparts.org/...s=&view=normal
jliu6789 (08-25-2012)
Old 08-25-2012 | 12:03 PM
01tl4tl's Avatar
ok, so I am obsessed with zip-ties, gorilla tape and glue,,it mounts ballast,,,res bottles,,,
Old 08-25-2012 | 09:09 PM
jliu6789's Avatar
Thumbs up yes it is the battery base in the bulkhead category
awesome. I searched all diagram but the battery base image is so small that I totally missed it. the part advisor in my local Acura Dealer couldn't even find it either. I suggest they should become Acura Zine member and earn some points first.
I will order one from the link you provided. zip tie does work temporarily but since I am going to keep this 2001 TL for a while, I need to use acura part to fix it.
my hat off to your guys !
Old 08-25-2012 | 09:37 PM
jliu6789's Avatar
another question on parts
  1. hi fsttyms1, I need 90137-SL4-003 tapping screw but one door couldn't hold door panel securely due to the damage to the "GROMMET" ? what's the matching GROMMET for the tapping screw to secure the door panel ? thanks. btw, who isn't the fan of beatles !
08KBP_VA
10-22-2019 01:55 PM
AJRozsa
10-05-2015 07:50 PM
ROSSARONIE
10-02-2015 11:46 AM
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
AmplifiedDetails
09-24-2015 02:55 PM
Quick Reply: the metal bracket holding coolant reserve tank
