Memory Seats & Mirror Problem
Being an Acha Bacha in
Alright well, I only noticed this problem after getting my Clifford Alarm installed, don't know if its related, maybe someone knows.
Anyways, the problem is that my seat positions are remembered in memory but the mirrors aren't. After installing the alarm, I lost the stock KEY FOBS and I use the Cliffford LCD Remotes, but I always thought the memory seat function would work if you just pressed the buttons on the door.
THe way it is right now, the car seems to remember the position of the seats but not the mirrors. And also after tilting down in reverse, the mirror doesnt tilt back to the same position as it was before the tilt instead it goes to some other position. I tried resetting it over and over but it will remain in memory for that time but on the next restart it will be lost again. Does anyone know what might be the problem?
I just hit 48k miles on my car so I'm out of warranty so I hate the fact that such a problem had to happen now.
I don't know shit about alarms, but I'm guessing that's what's causing the problem; some kind of an interference.
Take it back to where you got it installed and tell 'em to recheck it?
Mine works fine, I dont recall if it matters that the mirror button is not on the center. Check again with it in the center position. It is weird that is happening even when you go from reverse to park/drive that it doesnt normalize.
rockyboy
Aug 4, 2024 10:35 AM
billmcd
ILX
Oct 17, 2016 03:33 PM
BoricuaTL
Apr 8, 2016 01:08 PM
