Mechanical help
The problem I'm having is after the car is warmed up the idle keeps going from 6 hundred to 15 hundred back and forth continuously if anyone out there has had this problem and has fixed it please help
IMO: You may be experiencing an issue with the Idle Air Control Valve. I would remove the IACV, thoroughly clean, and reinstall it. After reinstalling the IACV, I would remove the clock fuse, for about 15 seconds, than replace it. Than follow the engine idle relearn procedure. While your in there, You may also want to clean out the throttle body area. Make sure, the engine has the correct spark plugs, by removing one, and checking it's type, and condition. It's possible, the intake manifold may also be "gummed-up, which could also contribute to an erratic idle. If you search this Forum, there is a DIY for the above listed fixes!
sorice
Aug 5, 2003 01:25 AM
