Lower Rpm Vibration
Lower Rpm Vibration
guys its been 3 months , i am having lower rpm vibration. when i drive the car and its on lower gear (between 1 and 2 or sometimes close to 2.) the car vibrates here and there. i have done tranny flash twice in 4 month, cleaned the egr valve, changed the timing belt, changed the oil, and it still vibrates. not sure what to should i do next? change the soleniod shifter? ATF FILTER? ANY ADVICE.
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
By vibrates what do you mean? Does it do it as its shifting or just driving? Check your motor mounts cor cracks (the side) leaking of fluid (these mounts are fluid filled) Have someone get in the car start it put their foot on the brake and put it in gear, while its in gear and their foot is on the brake have them slowly give it gas (you dont want the car to move and neutral or park wont work for this test) look to see if the motor moves much. If your mounts are original odds are they are shot.
I have the same problem. it thinks its my passenger side engine mount. the vibration is horrible when the car shifts from 1-2. i can ease down the vibration if I accelarate lightly and let off the gas for a second when it shifts gear. Happens only upon acceleration.
Also, If I'm at WOT the entire front end will shake from 0-60+mph.
Anybody else experience this problem?
Would you recomment replacing the front and side mount?
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
