loose parking brake
Old Feb 13, 2011 | 04:15 PM
mando90's Avatar
loose parking brake
i have a really loose parking brake its a foot brake and when i push it all the way down the car still rolls i have disk brakes all around and i have no clue on how to tighten my old car had a cable but i didn't see one under the car when i checked
Old Feb 13, 2011 | 04:17 PM
fsttyms1's Avatar
if you take the wheel off there is a rubber plug on the rotor. With that out rotate it to the bottom and with a flash light look into it. You will see what looks like a cowboy boot spur, with a screw driver you can roll it and it will apply more tension.
Old Feb 13, 2011 | 04:19 PM
mando90's Avatar
thanks man i appreciate it
Old Feb 13, 2011 | 04:57 PM
soria's Avatar
Just to clarify, it's the rear wheels you need to remove.
Old Feb 13, 2011 | 06:04 PM
01tl4tl's Avatar
our park brakes are a set of mini drum brakes located inside the rear rotors hub
There is a cable to each side under the car- that bent down thing you can see from a side distance
to do it fully right -
take apart to clean dust and lube self-adjuster system
then tighten until wheel wont rotate with hand pressure, now back off 6 clicks
Or without removing parts= tighten until slight drag is heard-done!
Old Feb 17, 2011 | 10:23 AM
mando90's Avatar
yeah thanks you guys i tryed it but my time ended up getting cut short but i think il try to get it done this weekend and fully do it right take the whole thing apart. so just so i know im doing it right i tighten the breaks until i cant turn the wheel by hand then back off 6clicks and that should be good to go after that and i do this to both sides correcrt?
Old Feb 17, 2011 | 10:29 AM
01tl4tl's Avatar
thats correct
when its all apart you need to spray clean and lube the adjuster `star wheel` system- same as old drum brakes
the tight and back off 6 clicks/notches should equal a slight drag on part of the rotation
rockyboy
Aug 4, 2024 10:35 AM
SidhuSaaB
May 30, 2020 12:40 AM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
jliu6789
Sep 8, 2015 08:02 PM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
