Loose headlights??
Old Aug 10, 2005 | 05:20 AM
strcdan's Avatar
Loose headlights??
does anyones headlights bounce up and down when u hit a bump at night? The beams jump up and down like the headlights are loose. i have a 02 tl-s . The dealer gave me new headlights but not bulbs,still same problem!! they look like when i hit a hard enough bump there loose , i checked the lights and there in there fine. dealer said it could be the springs holding the bulbs r bad, so they replaced both headlights.
Old Aug 10, 2005 | 07:59 AM
Dare_IL's Avatar
Need a WHAmbulance
If the bulbs are properly inserted and the spring is in place to hold the light bulb, there can't be any reason why they would act like that. Unless of course the whole housing is loose, but that is unlikely.
Because of the sharp HID light cutoff at the top of the light range, it may seem like they are boucing but no more than the car itself. Perhaps you might check your front struts and springs to make sure they are ok.
Old Aug 10, 2005 | 04:00 PM
strcdan's Avatar
the struts are fine the car has 30k on it. it rides fine, do u notice that at all???
Old Aug 11, 2005 | 07:58 AM
Dare_IL's Avatar
Need a WHAmbulance
If you drive over a rippled road it will really seem like they are loose. This is normal and happens because of the sharp cutoff at the top of the headlight pattern.
Old Aug 11, 2005 | 03:49 PM
strcdan's Avatar
no one else huh notices this??
Old Aug 14, 2005 | 03:30 AM
strcdan's Avatar
well i think it might be the bulbs. i cant figure it out. they are definitly loose somewhere.the headlights are brand new, what the hell else could it be??????
Old Aug 17, 2005 | 09:24 AM
CJITTY's Avatar
Ackniculous One
I thought the same thing when I first got mine. I took it back to the dealer and they re-grounded my headlights. When I hit a hard bump, sometimes I notice the lights somewhat "flicker" for maybe a .10 of a second. I always thought that was strange
Old Aug 24, 2005 | 06:27 PM
strcdan's Avatar
no i mean the bounce up and down like the bulbs are loose, anyone notice?? only when i hit a hard bump
Old Jun 5, 2007 | 09:01 PM
patientx's Avatar
I've noticed it too, only it happens even when I hit small bumps. I've replaced the bulbs, but not difference. It's really annoying. I've checked to make sure everything is nice and snug, including the spring holding the bulb in place. Everything appears OK. Any info would be great!
hashbrown
Feb 18, 2022 11:20 AM
ITSJESTER
17
Dec 6, 2018 02:29 AM
Mr.Tea
Oct 2, 2015 10:32 PM
Skirmich
Oct 1, 2015 12:59 PM
h22lude
Sep 27, 2015 06:22 PM
