LED Strip issues in 2002 TL
I'm losing my mind here, but does anyone know which is the dome light wire (weekday color (s) and where it is located under my dash? Trying to tap into the proper wire so the led strips will operate in sync with the dome light without a switch. Any help would be greatly appreciated! !!!
Relatively simple, either remove the top ceiling dome light's lenses cover to check for wiring color or just go to the passenger side fuse panel where you'll find that it's white & blue in color.
Cheers and good luck with the project !
carmis (04-02-2013)
