Issue with 2002 TL-S Seats in a 1999 TL
Hello all. First off I have searched for and found the diagrams for these seats into this chassis (thanks to fsttyms1). I made jumper harnesses using 1999 TL seat harnesses and 2002 TL-S chassis plugs because I cant de-pin these, being that the 1999 pins are too big for the 2002 plug. Here's an explanation of the issue.
1) Driver's seat does not move at all, and the seat heater does not work.
2) The passenger seat slides back and forth, but that's it. It does not tilt and the seat warmer does not work.
As for the wiring, one wire stood out to me. It is from pin 10 on the 2002 plug which is a WHT/BLU wire that is supposed to go to Fuse 11, which I can assume it requires voltage. And since I believe it does, what wire should I use for 12v?
Here is the wiring I did, in case someone can see if I did something wrong. I apologize for typing it all out. I just feel its better to post it up in case I had a really bad oversight.
Drivers Seat:
1999 to 2002
Pin 2 to Pin 7 BLK
Pin 3 to Pin 9 BLK
Pin 4 to Pin 17 WHT/BLU (extra WHT/BLU at pin 10)
Pin 5 to Pin 15 BLK
Pin 6 to Pin 19 RED/BLU
Pin 7 to Pin 8 RED
Pin 8 to Pin 21 BLK
Pin 9 to Pin 22 BLU
Pin 10- Pin 24 WHT/RED
Passenger Seat
1999 to 2002
Pin 2 to Pin 3 GRN/RED
Pin 3 to Pin 4 GRN/BLU
Pin 4 to Pin 2 BLK
Pin 5 to Pin 7 RED
Pin 6 to Pin 6 BLK
Pin 7 to Pin 9 WHT/RED
Pin 8 to Pin 8/10 BLK
Drivers Seat:
1999 to 2002
Pin 2 to Pin 7 BLK
Pin 3 to Pin 9 BLK
Pin 5 to Pin 15 BLK
Pin 7 to Pin 8 RED
Pin 8 to Pin 21 BLK
Pin 9 to Pin 22 BLU
Passenger Seat
1999 to 2002
Pin 4 to Pin 2 BLK
Pin 5 to Pin 7 RED
Pin 6 to Pin 6 BLK
Figured out how to get the driver's seat sliding/tilting by adding 12v to pin 17 (no other changes), but still haven't gotten the heaters going, or the tilting of the passenger seat.
rockyboy
Aug 4, 2024 10:35 AM
billmcd
ILX
Oct 17, 2016 03:33 PM
