Instrument cluster wont light up
Old Nov 3, 2010 | 11:04 PM
jaMezBOI's Avatar
philly flickin'
Exclamation Instrument cluster wont light up
I went to turn on my lights last night and came to realize that my cluster wont light up anymore...
What I did previously that may or may not have affected it:
Installed a double din... cluster was working fine for 5 days after the installation
I left my middle console out after the double din was installed because I stilled needed to run shielded rca cables to my stock sub for it to work with the aftermarket headunit. In the meantime I was still using my heated seat with the heated seat button plugged in to the plug just dangling. When I was plugging in the passenger side headted seat I didnt realize I tucked the plug away so I couldnt see it and I put the plug that is originally for the 12v outlet into the headted seat button. Didnt know it was the wrong plug untill a couple minutes later. Then put the corect plug in...heated seat still works fine and theres power going to the 12v accessory plug. (( that was earlier in the day )) That night I go to turn my lights on and nothing....cluster, climate control, vsa, sunroof, fogs, and memory seats all do not light up when I turn my lights on.
Already put a test light to all the fuses under the hood, passenger and driver side fuse boxes....everything is fine.
I got the wiring diagram from acura for the gauges but it doesnt show anything for the illumination... just the indivdual bulbs ie; seatbelt, vsa, cel, etc.
If you need that to help your solution just say so and ill post it/pm it
Any help/input would be greatly appreciated
Sep 17, 2015 10:16 AM
Sep 15, 2015 06:44 PM
brandnewcolony
Sep 12, 2015 10:39 AM
Allen_442
Sep 8, 2015 06:01 PM
