Idle issue after timing belt replacement
Old Jul 22, 2012 | 10:18 AM
JayRay's Avatar
4th Gear
Once I had my timing belt replaced my 2003 tl, it has an annoying idle issue. The r.p.m.'s go up and down either in park or in gear. The odd issue here is that it only hapens when the radiator fans turn on. I took it back to the mechanic twice and he checked the belt and said that the alignment is fine on the pulleys for the timing belt. I'm not sure if I trust him, but I'll give him the benifit of the doubt. Any recommendations?
Old Jul 22, 2012 | 11:03 AM
MilwaukeeDave's Avatar
Make sure he plugged all sensors back in. I installed my intake and left something unplugged by mistake and it make my car idle for shit. Check everything over an make sure nothing is loose.
Old Jul 22, 2012 | 11:23 AM
Check to see if the MAP and TPS sensors are switched around by accident.
Old Jul 25, 2012 | 07:33 AM
toyrotor's Avatar
^^check what they said, If everything checks out with that. Then he jumped a tooth on the gear. But its odd that you say it does it when the fans come on...
Old Jul 25, 2012 | 11:00 AM
01tl4tl's Avatar
give him another chance to check all connections
then take it to a place that knows acura
NOTE 03 has an idle relearn procedure after battery disconnected=
which may have been done for the service
ck azine for procedure- possibly in diy section or use search
Old Jul 25, 2012 | 11:32 AM
Stephen00TL's Avatar
Chapter Leader (Southeast Region)
Does the rpm drop if you have the a/c off then turn it on?
Old Jul 25, 2012 | 06:32 PM
JayRay's Avatar
4th Gear
Got Idle Fixed
I actually disconnected all the sensors that I could find,cleaned them off and re-connected them making sure I had a good conection. The idle position sensor (IPS),on the other hand, I have a feeling needed an adjustment. Took a dremel,ground a groove in the rivets and loosened them with a scewdriver.With a little adjustment, the idle works like a champ. Thanks for the help guys!
Old Jul 25, 2012 | 09:14 PM
01tl4tl's Avatar
did you do the correct `idle relearn` before randomly cutting things?
Old Jul 26, 2012 | 11:32 PM
JayRay's Avatar
4th Gear
Idle fixed
Nope. Didn't have to perform the idle relearn procedure.
Old Jul 28, 2012 | 10:21 AM
01tl4tl's Avatar
you should just to be safe
its easy
I have never heard of a tps prob that needed modifying!
Old Apr 10, 2014 | 06:20 PM
Saaax650's Avatar
Where is the Idle position sensor located on 03 tl ?
Old Apr 10, 2014 | 09:00 PM
Skirmich's Avatar
Idle Position Sensor? There isn't such thing as that in our cars.. The IACV don't work with any positioning system it reacts to Engine RPM like most modern vehicles.
Old Apr 11, 2014 | 06:58 AM
3.2TLc's Avatar
Lightbulb IAC valve......
Originally Posted by JayRay
I actually disconnected all the sensors that I could find,cleaned them off and re-connected them making sure I had a good conection. The idle position sensor (IPS) ,on the other hand, I have a feeling needed an adjustment. Took a dremel,ground a groove in the rivets and loosened them with a scewdriver.With a little adjustment, the idle works like a champ. Thanks for the help guys!
Hey Saaax650, in regards to your question on the Idle Position Sensor ? IDK !!!.........however, there's an IAC valve (Idle Air Control) which may be what ya need to look for underneath the TB. Also the TP Sensor (Throttle Position) is located on front of the TB.
Do some research on the IAC valve in the "DIY" sticky and other previous related threads. It tends to get gunked up and requires a periodic cleaning to help idle issues.
mada51589
Jan 9, 2025 04:40 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
asahrts
Sep 4, 2015 05:55 PM
NSolace
Sep 3, 2015 08:14 PM
