Idle ?
Old Mar 11, 2013 | 09:14 AM
hondakid23's Avatar
Idle ?
I believe I have a exhaust leak, im about to go to the shop and check it out, but wierd thing is that last night I was driving home from work and when I came to a red light The idle seemed high so i put the car in neutral and the Rpms were at 2,000 Rpms and would go back down to 1 when i put it in drive . If i put it in park it would also idle high around 2-2.5rpms . what could be the cause of this
Old Mar 11, 2013 | 03:00 PM
3.2TLc's Avatar
Neutral @ 2k & Park @ 2.5k = big problem when shifting the tranny into gear !
Check the IAC Valve as it may be sticking. Also, look over the throttle body area for any potential leaks.
Make sure all the vacuum lines are intact.
Old Mar 11, 2013 | 04:35 PM
TLer trash's Avatar
Also check the throttle body area for any mechanical obstruction. I've seen a walnut hold a throttle about 1/2 way open. Make sure there's a little slack in the throttle cable as well as the cruise control cable. Make sure your enemies haven't installed any double thick toyota floor mats.
Old Mar 11, 2013 | 06:14 PM
hondakid23's Avatar
I took it to a shop my flex pipe was cracked had it replaced for 130$ is that good? Also I got rid of the mid pipe and resonator and added a straight pipe for $150 do you think thats a bad price?
Old Mar 11, 2013 | 07:37 PM
assclown's Avatar
2000 acura tl FPR
Those listed seem like it would only contribute to an exhaust leak. I don't think it would have anything to do with an idle problem. Troubleshoot idle problem first.
Old Mar 12, 2013 | 12:17 AM
hondakid23's Avatar
I will clean IACV tomorrow.
Old Mar 12, 2013 | 04:22 PM
3.2TLc's Avatar
Talking Exhaust leaks fixed, but won't help the idle !
Hey Hondakid23, exhaust work and pricing will vary greatly depending upon the type of repairs or modifications done. It's best to check with more than one shop, just to compare options and pricing. If you require a service that you're not capable of doing yourself, then there's a gray area in the difference between what may be a good or bad price.
At the end of the day, it's your safety along with the workmanship quality that matters most !!!!
DerrickW
Nov 15, 2015 05:52 PM
012TL-GLM
Oct 5, 2015 06:32 AM
Skirmich
Oct 1, 2015 12:59 PM
mdlex389
4G TL Problems & Fixes
Sep 28, 2015 06:29 PM
prbori
Sep 27, 2015 01:37 AM
