I know my air intake hose is broken but...
I need help identifying what this hose is called and if i need to replace it along with the air intake?
Don't know much about cars but if its broken than it must not be good.
I appreciate the help.
![](https://cimg9.ibsrv.net/gimg/acurazine.com-vbulletin/960x1280/img_1342_729e44470c57cf6564cf698b26b56985d745df21.jpg)
![](https://cimg2.ibsrv.net/gimg/acurazine.com-vbulletin/960x1280/img_1343_8c467c4db1e67e566a97b4eb12ad72a135defee3.jpg)
![](https://cimg3.ibsrv.net/gimg/acurazine.com-vbulletin/960x1280/img_1344_60b4e42648aa71b56f64fd2b0a4d4c50fe8f34c7.jpg)
go to the junkyard/pick a part and go grab it. I wouldn't buy NEW per se..
or a good time for a cold air intake?
![Bite Lip](https://acurazine.com/forums/images/smilies/bitelip.gif)
the hose isn't necessarily broken though, just the air intake tube.
Yep if you are going to spend any money then drop in a Cold air Intake (preferred) or Short Ram Intake.
Otherwise try to find one off a TL in a junkyard or whatever. But don't delay as currently you're sucking unfiltered air into your valve train. If it's been broken for a while you may want to change your oil filter when you get the new intake installed.
the big problem is the open TB inlet- the system is made to be sealed from the air filter box to the TB
I don't see a hose clamp on the TB end of the intake tube? is it my eyes?
is there some back-story here that we need?
Just get it fixed asap. The metal tube supplies make-up air that the pcv system is removing. Any air flow, along with dirt, is going into the valve cover, and eventually the crankcase and oil.
like I was trying to explain, the open` TB to air snout to air filter` is like having NO air filter at all!
Biggie_B
02-26-2017 11:14 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
