I got a question?
Old Mar 15, 2011 | 10:34 AM
02TyPe_S_Tl's Avatar
I got a question?
I got a question on the trannys dip stick. Where does it mark full on the 2nd hole from the bottom or the hole that's on the very top of the dip stick. Thanx
Old Mar 15, 2011 | 11:03 AM
Failshed's Avatar
second hole from the bottom.
Old Mar 15, 2011 | 11:09 AM
alrite bro thanx I needed 2 no cuz I'm gettin a new tranny
Old Mar 15, 2011 | 11:56 AM
01tl4tl's Avatar
the only way to get the exact reading is this:
from cold, drive 15 minutes on freeway, get off and quickly park in safe level area
put trans in park, turn engine OFF
remove dipstick- wipe clean- insert fully and remove
Fluid level should be BETWEEN the 2 upper dots, NOT AT either one--BETWEEN!!
fluid level on the stick changes with temp--this is the book method to get it where acura wants
there is a lower mark for techs to use at dead cold but not as reliable as drive and ck
hopefully they install the correct amount on new trans but it never hurts to double ck
there have been reports of 1-3qts too many!! it only holds 7.3
Old Mar 15, 2011 | 12:11 PM
So then when I check it after I run on the freeway for 15min it should b between the 2nd dot from the bottom and the dot from the very top?
Old Mar 15, 2011 | 07:52 PM
01tl4tl's Avatar
lets just call them the UPPER 2 DOTs,, and ignore any lower dot
between them at 15 minutes- engine off- = correct level
Old Mar 22, 2011 | 05:03 PM
smokytllady's Avatar
3rd Gear
@01tl4tl Thanks for the info. I'm taking mine in for a tune up for the first time and this is good to know.
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
