Humming noise around 80 mph
Old May 5, 2012 | 01:58 AM
Mason Low's Avatar
5th Gear
about 90% of the time, my 2002 Acura TL Type S, 120k miles makes a humming noise at the front left of the car around 75-80 mph. Doesn't make the sound slower or faster than that range of speed. I have taken the car to 3 different repair shops and all say that there is nothing wrong, everything is tight and as it should be under the car. I'm at a loss, i know something is wrong but nobody can tell me what it is. Here is a link to a video of the noise that it makes, note that that is not the engine.
Old May 5, 2012 | 07:37 PM
fsttyms1's Avatar
have you tried rotating tires to see if it goes away? Typical humming noises are bearings.
Old May 6, 2012 | 01:09 AM
Mason Low's Avatar
5th Gear
YEah i did, i rotated and balanced them but its still there. THe mechanic told me that wheel bearings are ok.
Old May 6, 2012 | 11:07 AM
01tl4tl's Avatar
was he an acura specialist?
was a stethascope used to listen to cv and hub bearings?
were the wheels in motion with car on a lift?
find another mechanic!!
Old May 7, 2012 | 04:14 PM
TLer trash's Avatar
Wheel bearings are usually most noticeable at 35 -40 mph. At 80 mph I'd be looking for anything that would be affected by wind. Do you have a roof rack? Any loose body trim or door seals? Underbody shielding all intact and secure? Wiper arms/blades?
Old May 16, 2012 | 04:50 PM
Mason Low's Avatar
5th Gear
So update with the car, i took it to the dealership on sat. and they kept my car on monday only to tell me that they can't replicate the noise, that everything is fine around the car, and that they can't find the issue. Not even the dealership can find the issue. I'm screwed
Old Jun 7, 2012 | 05:37 PM
Mason Low's Avatar
5th Gear
Quick update, it was a sealing on a molding on the driver side of the windshield >.> I feel stupid. But at least its was fixed.
Old Jun 8, 2012 | 10:03 PM
acutee's Avatar
My accord has the same humming noise. Search google on accord trans whinning for this symptom. You are sure it is nothing to do with the electrical and stereo system, right?
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
